81 Users Online (80 Members):
Forums >> Revit Building >> Tips & Tricks >> Importing a METRIC CAD survey file generates topo lines at wrong elevation
![iamian33 Avatar](user_avatar/135203.jpg)
148 Posts No Rating |
Greetings ... I am trying to generate a Toposurface using the "Select Import Instance" command. In METRIC ... - My Revit environment is based on the Metric template supplied with Revit 2011. Units are set to millimeters ...
- the CAD file is in metric units w/ millimeters set as the Units.
When I create the toposurface, the points are not at the correct elevation. The CAD file has the contour lines at 516 but Revit generates the topo at 516000. I know that this is a meter vs. millimeter issue so I reset the units (CAD file) to "meters" but I got the exact same result. I've imported the CAD file with the units set to meters and then millimetersIf someone can offer help, I'd be truly grateful. Ian
Ian Shafer
Principal Consultant
True North S&F Consultants |
"I know that this is a meter vs. millimeter issue so I reset the units (CAD file) to "meters" but I got the exact same result. " - And in your Revit project did you cange your units to METERS too?
thanks for your interest. I did change the Revit file to import in meters ... but the cad file came in 1/1000 scale.I also changed the Revit file environment to meters but then the existing information (walls, level marks) also changed. Perhaps I need to import the site into a brand new model then set up the levels and re-add the walls ...?
Ian Shafer
imported topo file not elevating correctly |
Fri, Feb 29, 2008 at 12:56:01 PM
Importing AutoCAD topo 3D lines |
Wed, May 25, 2005 at 3:33:44 AM
Importing topo surface from CAD in Revit |
Fri, May 1, 2015 at 7:28:19 AM
Topography Elevation from Project Base and Survey Point is Incorrect |
Thu, Jan 29, 2015 at 10:32:24 PM
Importing a cad file |
Fri, Apr 27, 2012 at 3:33:21 PM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
