45 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> door family and to/from room selection
I have an overhead door family (I don't know where it originated from) that will not detect the from or to room for the schedule unless I offset it down 2'-6". Any idea what I need to do to the family to fix this?
This may be a room issue. Did you look at where the top of your room is? Otherwise, we would probably have to look at the family.
This user is online |
the top of the room offset is set at 8'-0. Other doors into the same rooms work. This door family doesn't work in any of the rooms.
Well ... it works if your room height is set higher .... as I suggested...
Thanks. Setting it higher did fix it. My doors were only 10' tall and I had been told as long as the offset was more than half of the door height it would work. Guess that was not quite true.
automating door schedule ( From room # To Room #) |
Thu, Jun 20, 2019 at 2:14:07 PM
A better method for family and family element selection. More like ADT pallets |
Wed, Jan 26, 2005 at 5:51:18 PM
room names not being picked up in door schedule |
Mon, Apr 21, 2008 at 10:26:48 AM
Door room boundary |
Thu, May 24, 2012 at 7:24:50 AM
Schedules. How do I avoid having a schedule row for every door, room & window? |
Wed, Aug 15, 2012 at 7:24:44 AM
Members: | 2019206 | Objects: | 22958 | Forum Posts: | 152184 | Job Listings: | 3 |
