Forums >> Revit Building >> Technical Support >> can you detail in 3d?
i was wondering is it possible to use revit's power to auto-document a detail element? what i'd like to do is create a full model version of a special window awning, at detail level, and then make plan, elevation, section views. i know this is possible as a separate 'projec't, but can such a thing be brought into a normal building project, like a group. i do not want it to be full-on detailed for each instance it is on the building, just once somehow. or should i just draw the detail in 2d and try not to be so wishful?
If it's an awning you will use again I would create it as a family, install it to its own project, create the details then export/import those details into a drafting view in your main project?
As you know you can add detail components to show in section/elevation at various detail levels. Unfortunately dimensioning/text notes cannot be set to be automatically shown at say "fine" detail level. There is no way that i'm aware of having these elements when placed in a detail component or window family show when loaded into a project (unless you start drawing it all as lines).
Best bet would be to include the detail components for the geometry, and as for the actual detailing create a group of the same name of the family and keep in a known location. This can be then loaded once the view is created and placed appropriately...
Nice idea though and certainly post it as a wishlist item. "The ability to associate pre-detailed views (sections/elevations/plans) with family items, so when they are loaded into the project the new views are automatically created as a 'standard details' set"
thanks heaps rythmick and mr spot for the suggestions. will look into it. i love revitcity.
Creating an Enlarged Detail View of a Detail I have Drawn |
Fri, Aug 31, 2012 at 7:05:30 AM
Detail components in multiple views. |
Tue, Aug 18, 2009 at 2:46:36 PM
Nesting Detail Components |
Mon, Sep 29, 2014 at 3:46:10 PM
link detail drawing from another drafting view in the same project |
Wed, Oct 12, 2011 at 11:14:01 AM
Multiple Detail Numbers In View Title |
Mon, Apr 11, 2011 at 12:24:55 PM
Members: | 2114960 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
