90 Users Online (89 Members):
Forums >> Revit Building >> Technical Support >> how to know the material used in a specific object?
40 Posts No Rating |
i did soem walls and later with paint i change the material . but later i dont know the name material . how i know the material used in the wall ? some comand to know the matrial used in an object?
There is no way to know what you painted it with. You can re-paint it with default and it will revert to what you assigned it in the wall type.
![JAMESHGRIMES Avatar](user_avatar/17328.jpg)
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
Actually if you used the "Paint" tool to apply the material you can see the name of the material. Just go into the paint tool and hover over the surface of the wall and look at the tooltip that pops up. if there is a material applied to that surface it will list it in the tooltip
I had forgotten about that James ... good pointer.
the name s material appears. thnaks a lot
25 Posts No Rating |
Thanks for the tip James - I wasn't aware of that.
Palm Springs Architect using Revit LT! |
Apply material to object style not working. |
Fri, Jun 15, 2012 at 7:33:23 AM
Hiding Surface Pattern For Specific Wall Material |
Thu, Feb 21, 2008 at 10:47:29 AM
Revit Arch. 2013 - Material Take-offs on specific areas |
Thu, Mar 7, 2013 at 8:23:26 AM
Material schedule not picking up materials in railing object |
Fri, May 6, 2011 at 4:03:35 PM
adding material to a dxf object |
Wed, Nov 9, 2005 at 11:13:34 PM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
