48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wrapping stairs
Mon, Aug 9, 2010 at 6:45:26 PM | Wrapping stairs
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
Can anyone help me with a stair question.
I'm not sure why revit creates the stairs in the attached drawing the way it does. I want to create a monolithic stair that wraps around a corner, but I'm not getting what I'm looking for.
Is there a way to get the stairs shown on the right by building only one set of stairs. When I try I get the stairs shown on the left.
Am I doing something wrong?
www.globaldesignstudio.com
Be Inspired!
Tue, Aug 10, 2010 at 6:14:22 AM | Wrapping stairs
4 Stars: 202 Votes
I can't check your model right now but i believe the issue is the same like this one: http://www.revitcity.com/forums.php?action=viewthread&thread_id=20312
Wed, Aug 11, 2010 at 12:07:26 PM | Wrapping stairs
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
Thanks for the reply,
It seems like it is the same issue, however neither of the links supplied in that thread are available, so I cannot see the answer you suggest.
Please note that these are monolithic stairs, not sure if that makes a difference.
Thanks for your help.
Be Inspired!
Thu, Aug 12, 2010 at 5:29:18 AM | Wrapping stairs
4 Stars: 202 Votes
"It seems like it is the same issue, however neither of the links supplied in that thread are available, so I cannot see the answer you suggest.Please note that these are monolithic stairs, not sure if that makes a difference." - Yes, we are talking about "Monolithic stairs", in that thread download the video from MEGAUPLOAD, you have there the link in my first post....
Thu, Aug 12, 2010 at 9:04:51 AM | Wrapping stairs
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
Thanks Typhoon,
I'm not able to see your video, when I try the link I get:
We're sorry! We were unable to locate the requested page.
Be Inspired!
Thu, Aug 12, 2010 at 9:39:43 AM | Wrapping stairs
4 Stars: 202 Votes
The link from Megaupload is fine, i just donwload right now, it's working....
Thu, Aug 12, 2010 at 2:59:25 PM | Wrapping stairs
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
If someone could just explain the issue that would be great. I don't know why, but I cannot see your video, the web page tells me that it is unable to locate the link. Not sure what that issue is.
I understand that the problem seems to be that revit calculates the underside of the stair as going straight from one sloped boundary to the other, and that interferes with the top of the stairs.
Can someone please explain the steps to work around this or else post a video in a different location.
Thank you very much.
Be Inspired!
Thu, Aug 12, 2010 at 3:17:45 PM | Wrapping stairs
Ty,  The link doesn't work for me either.
Thu, Aug 12, 2010 at 3:29:05 PM | Wrapping stairs
4 Stars: 202 Votes
You are right, the link goes directly to "Screencast" page and not to Megaupload, now I corrected the issue BUT if you Copy/paste that same link into another page it works fine....
http://www.megaupload.com/?d=5SI8K6ZO
Edited on: Thu, Aug 12, 2010 at 3:29:49 PM
Thu, Aug 12, 2010 at 5:27:03 PM | Wrapping stairs
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
Thanks very much.
Working now.
Be Inspired!
wall wrapping problems
Wed, Mar 4, 2015 at 9:59:03 AM
window jamb wrapping
Wed, Apr 13, 2011 at 4:26:53 PM
wrapping of wall inserts
Fri, Jul 14, 2006 at 5:13:19 PM
custom wall wrapping
Sun, Jun 20, 2004 at 1:05:47 PM
Wall wrapping
Thu, Jun 17, 2004 at 6:15:30 AM
Page generation time: 0.2510
