61 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Revit MEP - modilfy topography
Mon, Aug 9, 2010 at 4:30:00 PM | Revit MEP - modilfy topography
hchang
Hello, I have a issue and seeing if anyone can helo. I am using Revit MEP 2011. We received a Revit file and I need to modify the topography of the existing site plan. For some reason, when I select the topography, the edit boundary selection does not come up… I need to resize the existing bldg footprint. I tried filters and even placing a void in, but it does not work. Is it because Revit MEP don't handle topography and I have to use Revit Arch?
Thanks in advance.
H
Tue, Aug 10, 2010 at 7:02:26 AM | Revit MEP - modilfy topography
HDDWG2003
HDDWG2003 Avatar
3.5 Stars: 11 Votes
I THINK YOU ARE RIGHT. I DON'T REMEMBER MEP HAVING A SITE TAB. USE REVIT ARCH TO EDIT THE TOPO.
Wed, Aug 11, 2010 at 7:30:47 AM | Revit MEP - modilfy topography
hchang
Kinda what I thought. Thanks for confirming it.
H
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Revit MEP
Wed, Oct 28, 2009 at 10:10:40 PM
building and topography
Tue, Jun 23, 2009 at 8:17:08 AM
TOPOGRAPHY SPLIT PROBLEM
Mon, Sep 22, 2008 at 2:51:42 PM
Revit 2015 - Underground Pipes Set Distance Below Topography
Mon, May 4, 2015 at 1:04:32 AM
Page generation time: 2.5861
