Forums >> Revit Building >> Technical Support >> how to turn on the hatching Pattern for topo in section
77 Posts No Rating |
In my section cut, I couldn't see the hatching pattern of the topo I made. I have tried use material (site earth) to it. In that material, I set a cutting pattern to the topo, but it doesn't work.
Massing and site tab, model site / site settings (pull-down arrow) - Set your hatch here and how deep you want it to show.
Be sure to check Site Settings. Make sure that the section cut material in the section graphics is set to the material you want.
Sorry, WWHub beat me to it.
"Massing and site tab, model site / site settings (pull-down arrow) - Set your hatch here and how deep you want it to show."
69 Posts No Rating |
Are there any updates on having multiple cut patterns for topos?
41 Posts No Rating |
It is now 2012. In R13, It doesn't seem as though there is yet an option to have multiple settings for the topo material in cut section. Is that true or is there some gizmo somewhere controlling that secondarily that I haven't found? I'd love to put a different material designation for a couple of different phases of grading.
Topography and hatching in section / elevation |
Sat, Sep 27, 2008 at 7:55:42 PM
Concrete hatching ? |
Tue, Jan 21, 2014 at 3:58:05 PM
Changing line weights to hatching? |
Wed, Apr 26, 2006 at 10:44:01 PM
Topography Hatching |
Tue, Feb 28, 2012 at 8:15:32 AM
Surface pattern to Topo surface |
Mon, Aug 19, 2013 at 10:50:11 PM
Members: | 2100940 | Objects: | 23173 | Forum Posts: | 152292 | Job Listings: | 3 |
