156 Users Online (154 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Brick Corbelled Foundations
Mon, Aug 9, 2010 at 8:10:43 AM | Brick Corbelled Foundations
Daveybdab
Hello
I am working on an existing brick building in revit. I have drawn all the existing masonry walls (i modeled them in place as they are fairly irregular). I am now starting to add the foundations to the building and wondering if anyone has added brick corbelled (stepped) foundations sitting on a concrete strip footing before. The 'wall foundation' function does not seem to recognise my walls (possibly because i modeled them in place), so i imagine i would have to model the foundations in place aswell. Any ideas?
thanks for your help
Mon, Aug 9, 2010 at 8:46:13 AM | Brick Corbelled Foundations
You should add an image of your walls.  We may have been able to show you how you could use walls instead of modeling in place.
Not sure about what you mean about a corbelled foundation.,  With regular walls, if the bottom of the wall steps, the foundation will step.
Adjust Brick veener to move down agianst the brick ledge.
Thu, Jul 26, 2018 at 2:23:14 PM
Brick Colour
Mon, Jan 13, 2014 at 9:27:04 AM
foundations
Wed, May 14, 2008 at 1:13:54 PM
brick sill below window on brick wall
Thu, Mar 13, 2008 at 6:10:24 PM
CMU + brick wall- brick is NOT bearing
Tue, Dec 22, 2009 at 3:16:31 PM
Page generation time: 0.6264
