48 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Gray Gloomy Interiors Revit 2010
Mon, Aug 9, 2010 at 12:34:13 AM | Gray Gloomy Interiors Revit 2010
RevitStudent123
I appreciate anyones help. I used Revit 09 and found I could get decent interior rendering in 30 minutes.
Revit 2010 is very diffcult to use for interiors. The attached Revit 2010 file is rendered at best, scheme is Sun Light
interiors only, Spring Soltice,. I made some minor changes to the image adj.  I tried "custom settings" and at the
bottom I checked the box for windows. All I got was an illuminated glazing area and a black room. I have done
20 test renderings and I am getting no where. The glazing is a glass block row copied up many times.
The material instances is for clear glass 100 % transparencey. My walls are lite blue glossy, lite biege carpet.
I just need normal lite to penetrate. Thanks for anyones help. The apt is from 2008.
Mon, Aug 9, 2010 at 12:35:46 AM | Gray Gloomy Interiors Revit 2010
RevitStudent123
Gray walls
Tue, Jun 13, 2006 at 1:07:37 PM
Rendering coming out gray
Wed, Jul 19, 2006 at 5:49:21 PM
Specialty equipment comming in gray.
Thu, Jul 22, 2021 at 7:28:40 AM
12
Splitting Master Model into separate Interiors and Docs Models
Wed, Aug 21, 2013 at 7:24:50 AM
Doors make a gray shadow in Sections
Wed, Apr 7, 2004 at 10:39:43 AM
Page generation time: 2.6893
