66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Calculated value
Fri, Aug 6, 2010 at 11:28:51 AM | Calculated value
TKennedy
4 Stars: 7 Votes
Hello, I'm suffering from a bet of cognitive flatulence this morning, and I'm hoping someone can help me. I have a text parameter, and I need to use it in a calculated value in a schedule. If the parameter is blank, I need the calculated value to be blank. If the parameter has any value in it, I need the calculated value to place an "X" in the schedule. Is this possible, and if so, what would the formula look like?
I can create a new Yes/No parameter if I absolutely have to, but that would be duplicating info, and I'd rather avoid that. If it helps, the text parameter is for the NEMA type of a cord connection, and the "X" in this particular schedule indicates if the piece of equipment has a cord connection or not.
Fri, Aug 6, 2010 at 12:48:47 PM | Calculated value
Sorry... from the HELP - Conditional statements can contain numeric values, numeric parameter names, and Yes/No parameters  We have no formula operations for text except I believe =.
Fri, Aug 6, 2010 at 1:42:33 PM | Calculated value
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
I may be mistaken here, but I believe you can...however I think it may only work when calling out a visibility parameter.
ex: if(Parameter 3, "X", " "Winking where Parameter 3 is a yes/no.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Fri, Aug 6, 2010 at 1:43:06 PM | Calculated value
brettgoodchild
4 Stars: 17 Votes
stupid emoticons!!
if(Parameter 3, "X", " " )
Edited on: Fri, Aug 6, 2010 at 1:46:29 PM
                             ~ Abraham Lincoln
Fri, Aug 6, 2010 at 1:47:18 PM | Calculated value
brettgoodchild
4 Stars: 17 Votes
HAHA!!!!
I would disregard my last post!
I just reread the OP and basically confirmed what HUB just said...I'll write this off as being Friday and tired.
                             ~ Abraham Lincoln
Fri, Aug 6, 2010 at 2:17:19 PM | Calculated value
TKennedy
4 Stars: 7 Votes
Thanks guys, that's what I figured.
Calculated Values in Room Tags
Wed, Mar 30, 2011 at 4:08:03 PM
Calculated Value
Mon, Dec 13, 2010 at 4:46:58 PM
Calculated Values
Mon, Mar 20, 2006 at 12:58:54 AM
Calculated totals of formula in schedule
Fri, Sep 11, 2020 at 7:14:07 AM
How can I create calculated sloping ductwork, with elbows?
Sun, Feb 18, 2018 at 3:12:08 AM
Page generation time: 0.2716
