46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> 1 deg pitch
208 Posts No Rating |
Hi all,
I am trying to create a roof with a 1 deg pitch.
Revit tells me it can't create the roof with this pitch. The best it can do is 3 deg.
Is there a default setting I need to adjust so that a 1 deg pitch is possible.
cadjockey
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
There are no settings for minimum pitch that i no of and i an having no problems creating a roof with a 1 degree pitch...?
What type of roof are you creating? Is it sloped glazing?
![latemore Avatar](user_avatar/6368.jpg)
![3 Stars: 2 Votes](/images/stars_3.gif) |
i just tried mr spot's suggestion of a 1 deg roof - no issue.
at the risk of stating the obvious, is your sketch fully closed? is each slope side at the correct angle?
Hi guys,
The roof is a very simple form. I have created a simple roof structure : a 200mm structure layer and then a 50mm finish layer I have called sheet metal.
The roof footprint is a simple square and the sketch is closed. I have toggled three sides and left one side un-toggled (at my box gutter) in order to create the slope angle. The roof is based on a common wall plate level and offset as required.
This should be simple.
Is it a glitch with version 7.0 as this is what I am currently using.
cadjockey
Shouldn't be a glitch in version 7 as i don't remember every having issues with that as i'd often have 1 degree pitched roofs.
When you explained it have you got 3 sides defining slopes? or 1? The side to host the gutter should be the only slope defining line.
Unfortunately i don't have a copy of Revit 7 installed to test...
Mr Spot,
The only side with a pitch is the gutter edge.
cadjockey
a thought -
have you put negative 1 degree on the slope defining edge by any chance? i have managed to use negative slopes at the 'head' of a roof, and it works.
also, based on many roof comments in revitcity, maybe you should try a slope arrow?
I found the problem.
You cannot have a pitch lowere than 3 degress if you have your rafter cut set to 'two cut square'.
At least with version 7
cadjockey
another double pitch roof question! |
Thu, Jun 14, 2007 at 10:42:50 AM
Pitch Formula |
Wed, May 2, 2007 at 9:34:35 AM
Duel Pitch Roof |
Tue, Feb 10, 2009 at 2:11:10 PM
Bay window roof pitch |
Fri, Apr 7, 2006 at 1:01:50 PM
Double sloped hipped roof |
Mon, Jun 27, 2011 at 2:18:55 AM
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
