55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Tips & Tricks >> BLUE SECTION CUT SYMBOLS
Thu, Aug 5, 2010 at 10:45:26 AM | BLUE SECTION CUT SYMBOLS
AlienEd2010
CURRENTLY I AM PRINTING SOME DWGS FROM REVIT TO PDF. BUT THE SECTION CUT SYMBOLS WILL NOT PRINT BLACK. IS THERE A WAY TO CHANGE THE COLOR OF THE SYMBOL FROM BLUE TO BLACK?
Thu, Aug 5, 2010 at 10:53:06 AM | BLUE SECTION CUT SYMBOLS
The blue indicates the view is not placed on a sheet.  Place it on a sheet and it will turn black.  Otherwise, this is a system setting and I don't believe you can change it.
BTW - In the print setup, you can choose not to print these at all since there is no references....
Edited on: Thu, Aug 5, 2010 at 10:54:18 AM
Thu, Aug 5, 2010 at 12:18:13 PM | BLUE SECTION CUT SYMBOLS
AlienEd2010
THEY ARE REFERENCING VIEWS AND THEY ARE STILL BLUE. I HAVE THEM REFERENCING DRAFTING VIEWS AND THE VIEWS ARE PLACED IN A SHEET... BUT STILL BLUE
Thu, Aug 5, 2010 at 12:44:29 PM | BLUE SECTION CUT SYMBOLS
Now I understand what you are asking.  For almost everybody, when we print revit to PDF or printer in B&W or in color, the blue section cuts (views on sheets) always print black even though they are blue on the screen.  I did see where someone else asked this question but I only saw it once and I did not see where anybody had an answer. ....
Thu, Aug 5, 2010 at 12:48:39 PM | BLUE SECTION CUT SYMBOLS
AlienEd2010
WHEN I PRINT TO PDF. I SELECT PRINT BLACK IN THE ADOBE PRINT OPTION. BUT THEY COME OUT "GRAYED" TO BEST DESCRIBE IT BUT NOT BLACK.
Thu, Aug 5, 2010 at 12:51:30 PM | BLUE SECTION CUT SYMBOLS
AlienEd2010
DUH!!! NOW I GOT IT. I DIDNT EVEN BOTHER TO CHECK IN THE PRINT OPTIONS IN REVIT!!!
I WENT INTO PRINT SETUP UNDER APPEARANCE\COLORS. SELECT BLACK LINES.  PROBLEM SOLVED.
I DONT FEEL SO DUMB NOW Smile
THANKS FOR THE REPLY.
Some levels blue, some black
Thu, Jun 16, 2011 at 7:08:06 AM
Color of the Cut
Mon, Dec 28, 2009 at 1:44:41 AM
My section cut symbols don't show on the floor plans
Thu, Apr 10, 2008 at 8:08:12 PM
Blue items show up red
Mon, Dec 9, 2013 at 4:14:27 PM
DIMENSIONS OVERRIDES
Mon, Nov 14, 2005 at 11:02:00 AM
Page generation time: 2.3506
