45 Users Online (44 Members):
Forums >> Revit Building >> Technical Support >> Shifting Sweep
I'm confused. I have created a HM window family. The window has a single horizontal mullion (which is a sweep). Looks fantastic in while in the family but when I load it into a project it shifts to the inside a few inches. What am I missing? I have adjusted the reference plan that the sweep is created on and nothing. Revit 2011. Thanks
OK I think it has to do something with the wall it's placed in. How do I lock that sweep to the rest of the frame? Thanks again
"How do I lock that sweep to the rest of the frame?" - ALIGN tool check your HELP
appreciate the responce, but it will not allow me to align. I can "Move" the sweep but when I use align, the sweep will not move. It's as if it has a "Center in wall" option checked somewhere that I'm not smart enough to find.
First you must edit that sweep, then select the path and edit too, now you have your path with magenta color right? Now use the Align tool and lock the padlokcs, if you have created that path using the "Pick 3D edges" option, the path automatically attach to the frame...
Ceiling Hosted families shifting with ceiling |
Thu, May 8, 2008 at 12:35:40 PM
Shifting Elements in Wall Sections |
Thu, Mar 12, 2009 at 12:39:23 PM
POWERFUL PC -> slow view-shifting |
Wed, Aug 10, 2011 at 4:51:42 PM
Can You Flex a Sweep in Components |
Mon, Jun 3, 2013 at 2:09:23 PM
Sweep Profiles in Version 9 |
Thu, Aug 3, 2006 at 2:14:05 AM
Members: | 2042232 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
