93 Users Online (91 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Underlay in Site Plan
Thu, Aug 5, 2010 at 5:15:42 AM | Underlay in Site Plan
rdavies1973
rdavies1973 Avatar
Hi All
 Am new to this whole underlay business.
 Start point: Have my site plan open with a property line all mapped out.
Next stage: Go to view properties, change underlay to ground floor, as I want to see the ground floor to trace ... so I can show on the site plan. Nothing shows. I have left the site view depths as default ... i.e. unlimited at massive offsets.
 Am I doing something wrong, or is this function not available for the site plan?
Any feedback as to the best way to achieve this result?
Thu, Aug 5, 2010 at 7:07:23 AM | Underlay in Site Plan
3.5 Stars: 395 Votes
I'm sorry, I don't quite understand.  You say you want to trace your gorond floor on the site plan.   Revit is not CAD unless you are only using it as a drafting program.  If you are modeling your structure, it will show in the site plane and you don't need to trace anything.
If your plan is just 2D linework, then that is your problem.  2D lines and other annotative elements do not show up in underlays.  In this case, copy your lines to clipboard, switch to the site plan and paste same place.
Fri, Aug 6, 2010 at 3:22:12 AM | Underlay in Site Plan
rdavies1973
rdavies1973 Avatar
Hi WW
Haven't explained myself well. I don't want to use Revit as a 2D tool. My understanding is (correct me if I'm wrong) is that an underlay can be displayed, linework (not sure if model or detail lines) can be drawn around the underlay ... and that linework will change if the walls etc are moved or modified at a later date. This was explained to me for showing the roof outline in a floor plan without having to redraw it each time there was a change.
I realise that I can display the ground floor in the 'site' layer, but that's too much detail for the style of drawing that I want/need to adopt. Really just want to show an outline of the ground floor/porch etc and roofline in site plan view.
Fri, Aug 6, 2010 at 8:26:01 AM | Underlay in Site Plan
As I said: " 2D lines and other annotative elements do not show up in underlays. "....  Turn on your model in the site and add the 2D linework showing what you want - then turn off your model.
Cant see site features in First Floor Plan
Thu, Jan 31, 2008 at 7:10:59 AM
REVIT 2015 - Underlay: EXPORT?
Tue, Aug 5, 2014 at 2:54:54 PM
misguided underlay
Tue, Feb 19, 2013 at 8:14:29 AM
underlay
Mon, Aug 11, 2008 at 6:18:01 PM
Underlay.... problems
Tue, Jul 31, 2007 at 11:36:03 PM
Page generation time: 0.9163
