113 Users Online (111 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> ABOUT SET UP WORK PLANE
Thu, Aug 5, 2010 at 12:47:08 AM | ABOUT SET UP WORK PLANE
terrywu218
terrywu218 Avatar
Hi, I'm using Revit 2009 version now. I got some question hope you guys can figure it out.
I need create a canopy structure by MODELLING-CREATE-SOLID FORM-SOLID SWEEP. But I can't set up an appropriate work plane, like profile shows in elevation, path shows in plan. That is to say I only can operate based on plan (Floor 1,floor 2, etc.) or give it a Z direction parameter in plan view.
Some one told me that pick up unbased on plan when openning a template, then "Work Plane-based" and "Always vertical" under FAMILY TYPE-Family Parameters, and I could create family with slope and something else.
If my understanding is wrong, please help me show the correct steps. Thank you Thank you!!
Thu, Aug 5, 2010 at 5:30:01 AM | ABOUT SET UP WORK PLANE
4 Stars: 202 Votes
Revit 2009? hummmm long time, First you must learn how to use the Work Plane, you can use ref. planes and ref. lines to help you, you can draw your path in the right plan view, then change your work plane to a ref. plane and now you are working in a elevation or section view like you want, more, after you create and finished your path in plan view you can change to a 3D view then go to a view > Orient by plane and choose the profile plane then draw the profile in that 3D view.
Edited on: Thu, Aug 5, 2010 at 5:33:13 AM
Thu, Aug 5, 2010 at 6:28:12 AM | ABOUT SET UP WORK PLANE
HDDWG2003
HDDWG2003 Avatar
3.5 Stars: 11 Votes
TYPHOON IS RIGHT REF. PLANE IS WHAT YOU WANT BUT HE LEFT OUT YOU MUST GIVE THE REF. PLANE A NAME TO USE IT IN THIS METHOD. GOOD LUCK!!
Thu, Aug 5, 2010 at 9:13:20 AM | ABOUT SET UP WORK PLANE
terrywu218
terrywu218 Avatar
Thank you guys!
Another question, I'd like to learn about systems in US. Is Windows 7 64bit prevailing? I mean do most softwares have new version for Windows 7 64bit or 32bit?
Thu, Aug 5, 2010 at 9:29:13 AM | ABOUT SET UP WORK PLANE
4 Stars: 202 Votes
HDD there is no need to give a name to a ref. plane, like i said "you can draw your path in the right plan view, then change your work plane to a ref. plane (select Set work plane then choose PICK PLANE, now you pick on the ref. plane you want, no need to have a name) and now you are working in a elevation or section view  (you choose)", what you are talking about is if you are in a 3D view and you want to orient the work plane to that (named) ref. plane you need previous to give a name to that ref. plane.
Edited on: Thu, Aug 5, 2010 at 9:44:56 AM
Thu, Aug 5, 2010 at 9:30:56 AM | ABOUT SET UP WORK PLANE
terrywu218
terrywu218 Avatar
Thank you guys!
Set roof or soffit on work plane?
Mon, Dec 2, 2013 at 12:57:49 PM
14
cant set work plane
Fri, May 11, 2018 at 1:06:35 AM
Floor & Work Plane Error Message
Thu, May 4, 2017 at 8:01:02 PM
set up of 3 point plane
Wed, Dec 7, 2011 at 8:38:23 AM
Work Plane Error
Thu, Nov 5, 2009 at 8:41:13 AM
Page generation time: 3.3418
