99 Users Online (98 Members):
Forums >> Revit Building >> Technical Support >> Wall opening affects wall joins
57 Posts No Rating |
When I create a wall opening in this stacked wall, my corners are no longer joined neatly mitred (Revit Architecture 2011)
After you create the stacked wall you can disassociate the SW, just select then right button, it's like you can "explode" that wall in two and work in them separately....
Thanks Typhoon, That worked, I am just not sure why! Does a stacked wall need to be treated as separate walls when items are inserted?
"Does a stacked wall need to be treated as separate walls when items are inserted? " - I think that's what you must to do when you work with stacked walls... Cheers
Does anyone else wish that there was a toggle to make wall joins the default off |
Wed, Aug 19, 2009 at 9:49:42 AM
Can you make wall joins Miter by Default? |
Wed, Dec 21, 2016 at 1:52:44 PM
14
Wall joins in linked files |
Mon, Aug 19, 2013 at 2:58:42 PM
Wall Joins |
Tue, Feb 3, 2004 at 6:37:20 PM
I hate the Revit Automatic Wall joins |
Thu, Oct 25, 2007 at 9:59:44 AM
Members: | 2017060 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
