46 Users Online (44 Members):
Forums >> General Discussion >> Revit Project Management >> "Dummy" Hardware Schedule
16 Posts No Rating |
I am wanting to create a Door hardware schedule for our template and would like to manually type in quantity, but as I put in quantity 3 it puts 3'-0" in the box. I know it is a setting but not sure which setting it would be. Also, next question, in this same schedule I would like to have 3 rows followed by the next group (or next header). I am unsure how to set that up in the sorting or formatting. See attached, thanks so much
Your problem with quantity is that you made this parameter a length. It needs to be a number. Schedules in Revit are not very flexible. You can not add the three blank rows. But you can split your schedule in the sheet view and move the sections apart. (And you could add lines in paper space if you had to .... but I would not.)
That makes sense, but what if "Type of Parameter" box is grayed out (uneditable)?
"Room From" and "Room To" NOT updating in Door Schedule??? |
Wed, Jan 20, 2016 at 1:17:43 PM
Auto "Quick" Schedule |
Wed, May 28, 2008 at 1:08:02 PM
I can't see "Height" parameter value of Wall or Currtain Wall Schedule? |
Thu, Apr 27, 2017 at 2:04:39 AM
Blank/Dummy Schedule 2012 |
Mon, Jan 30, 2012 at 3:27:59 PM
new sheets - don't want them in my "drawing list" schedule |
Fri, Jan 16, 2009 at 2:43:17 PM
Members: | 2022322 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
