62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Wishlist >> Improve 'Calcuated Values' to work as AutoCAD Architecture
Wed, Aug 4, 2010 at 8:03:57 AM | Improve 'Calcuated Values' to work as AutoCAD Architecture
archie456
3 Stars: 1 Votes
I've just moved from AutoCAD Architecture to Revit.I'm quite happy with Revit, its quite good, except creating complex Calculated Values. AutoCAD Architecture is much better at this as you can enter almost any VBA expression.Revit cannot even evaluated text string.Really disappointing...
Problem import Autocad file that contains ''proxy entities''.
Wed, Mar 17, 2021 at 7:38:19 AM
Autocad Architecture join the Revit Architecture Suite
Tue, Aug 19, 2008 at 9:14:55 AM
Incompatibility between ''Bluebeam'' pdf fillar and Autocad dwg.
Wed, Aug 19, 2020 at 7:59:03 AM
BEWARE - Parameters don't update.
Thu, Sep 1, 2005 at 11:36:58 PM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Page generation time: 1.1055
