73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> How to customise a Section Tag or Edit a Section Tag
Wed, Aug 4, 2010 at 5:46:21 AM | How to customise a Section Tag or Edit a Section Tag
fennie77
4 Stars: 4 Votes
Can I check with you if I can customize the Section Tag or edit the existing Section Tag. The existing Section Tag has a number on top & a divider line with  the sheet number below, can I just have the number & nothing else?because when the sheet number is too long, it is very untidy & ugly.
Wed, Aug 4, 2010 at 8:55:48 AM | How to customise a Section Tag or Edit a Section Tag
DELREVITGURU
DELREVITGURU Avatar
3.5 Stars: 6 Votes
You should be able to make a new section tag in the family editor.  The catagory would be annotations.  You can design the tags and use parameters for the text that you wish to enter.  The text parameters are done the same way as you would customize a sheet for documentation.  Hope this is what you were asking.
EE & A Designs
Section tag missing on plan but section still exists
Tue, Nov 22, 2016 at 2:58:16 PM
Custom Section Tag Rotating Lines
Tue, Jul 31, 2007 at 1:23:43 PM
location of the elevation tag and section tag
Tue, Aug 10, 2010 at 10:07:11 AM
section tag
Mon, Oct 27, 2008 at 4:14:49 PM
Floating Section Tags
Mon, Nov 26, 2007 at 1:09:04 PM
Page generation time: 0.7976
