45 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Walls, Floors, Structural Framing are MOVING automatically When I select them!!
Wed, Aug 4, 2010 at 2:58:41 AM | Walls, Floors, Structural Framing are MOVING automatically When I select them!!
CNMSD
Hi,
Something real weird is happening. I finished my structural model (in 2011 version) and then I detailed it using a combination of the model elements as well as 2d lines. I issued the drawings and happy days. I came back to the model a couple of days later and was extremely suprised to find that every time I clicked on an element, whether it be a wall, floor, roof purlin or beam EVEN MY TITLE BLOCK ON A SHEET ....It phsically moves up the page (in any view, this includes views on sheets). And if I select it again, It will move again, and again every time I click on it. The only thing I have done since working on the model is installed the batch print from the subscription centre.
WHAT THE HELL IS GOING ON!! I can't do anything because of this.
Please help..
Wed, Aug 4, 2010 at 11:15:02 AM | Walls, Floors, Structural Framing are MOVING automatically When I select them!!
gregroberson
gregroberson Avatar
THIS ISSUE SUCKS...JUST HAPPENED TO ME A FEW DAYS AGO.
Are you working over multiple monitors or have "un-docked windows" floating around on your screen.  That was my issue.  I found an old post (to give the originator props)...
1. Close everything but Revit
2. Dock all your windows.
3. Put Revit on your PIMARY screen.
4. Maximize Revit.
5. Save the project.
6. Completely exist Revit and reenter.
I hope this works for you, it did for me.
Greg
Wed, Aug 4, 2010 at 11:19:00 AM | Walls, Floors, Structural Framing are MOVING automatically When I select them!!
3.5 Stars: 396 Votes
Do you have press and drag turned on?  Bottome of screen check box.
Wed, Aug 4, 2010 at 10:40:56 PM | Walls, Floors, Structural Framing are MOVING automatically When I select them!!
CNMSD
Thanks so much guys for your help. WWhub you were correct. I must have accidently turned on the press and drag. Everything good now. Wow, always the simplest things cause the most mystery.
Wood Framing Walls Extension; Locating and External framing
Fri, Jul 31, 2015 at 8:03:14 PM
Update Structural Framing with Updated Conceptual Mass?
Thu, Mar 12, 2015 at 6:54:55 PM
panel walls - getting walls to subdivide automatically with joints already in.
Wed, Nov 24, 2010 at 6:22:27 PM
structural framing family cut pattern interacting with wall in section 2017
Wed, Sep 5, 2018 at 12:52:56 AM
Structural Framing Plans/Callout Beam Sizes
Wed, Feb 22, 2006 at 5:49:10 PM
Page generation time: 6.9990
