87 Users Online (86 Members):
Forums >> Revit Building >> Tips & Tricks >> How to import a CAD model into Autodesk Revit Architectural 2010's layout plan?
![4 Stars: 4 Votes](/images/stars_4.gif) |
Anyone can help me? I was given a autocad 3d model in dwg file, the file was also imported into Revit & saved as rte & rvt format. I tried to copy & paste rte & rvt into my current project, however, it is not shown on my layout plan, message: "None of the created elements are visible in Floor Plan: General Layout Plan - 4th Storey view. You may want to check the active view, its parameters, and visibility settings, as well as any plan regions and their settings" I also tried to import cad into my current revit project, i get the same message. Anyone know how I can " reveal " the cad model which was brought into my revit project? I need to replace the furniture system in my current revit project with this new furniture system which was created in autocad. Thanks
In Revit, go to a elevation view and check if your CAD file is upper or down than your model, sometimes you have your Revit model at Z= 700m elevation and your CAD at Z=0m so you can't see that cad file in that plan view because of that...
Thanks for your reply. So if let's say the elevation is really different, how do I change the elevation to match my floor plan?just move the cad file??
I tried to look in elevation, but I cannot see the cad layer at all, anyone please help, thanks!
CAD Import Level Association |
Thu, Jan 31, 2008 at 1:06:17 PM
Sketch-Up into Revit 2010 |
Wed, Mar 3, 2010 at 12:40:42 PM
Revit 2010 Dwg. Import problem |
Thu, Sep 2, 2010 at 1:52:03 AM
Cadd architectural site plan mystery |
Wed, Jul 16, 2008 at 2:28:51 PM
Linked CAD site plan appears 'crushed' in Revit |
Tue, Apr 2, 2013 at 11:00:08 AM
Members: | 2017104 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
