64 Users Online (62 Members):
Forums >> General Discussion >> Revit Project Management >> Import shared parametres at once
56 Posts No Rating |
Is there any way to import all shared parametres into project from Sheet template I created at once? We have about 20 parametres in sheet that we want to edit in project (name of company we work for on this, date and so on) But we have projects that takes about 2 days to complete in Revit, so we dont have time to add all parametres from all types of sheets to add manually again and again. I've created RTE file, but our pojects are made about 0,5 year before printed (used) so it will take next 0,5 year to use RTE files. Since than is there any way to add all these parametres when i load sheet template? Maybe the text file somehow? I work in RAC 2010 but soon 2011. thx for any help
Yes, Open the template, then open the Project. Go to manage tab. Click on "Transfer Project Standards". This will let you transfer any "Standards" from the template to the other. You will notice that all categories are checked by default. You might want to uncheck all and then select only the categories you need to transfer. The parameters you asked about are contained in the category "Project Parameters"
Thank you, it worked! Now for some questions from others, i was confused because transfer didnt work. Than i realized i need to be in new project and "Import" the standards. At first i was trying to be in Template and export them, silly me ...
Batch Import Shared Parameters |
Thu, Feb 26, 2015 at 4:50:11 PM
Sheets |
Thu, May 20, 2010 at 8:49:06 AM
Gotta start learning Revit again |
Thu, Aug 12, 2010 at 2:41:13 AM
to import shared parameters with formulas. |
Fri, Jun 20, 2014 at 7:19:05 AM
materials not updating with famalies? |
Thu, Apr 30, 2009 at 3:22:48 AM
Members: | 2030502 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
