57 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> Working out door location for schedule
Hi, Traditionally in our door schedules we always have a column which tells the reader which room the door is located within. This is quite easy to set up in AutoCAD Architecture. Is there a way to do this in Revit? Cheers.
In the door schedule..."Select available fields from"... To Room / From Room. You will need to learn how revit determines the to and from.
Excellent - Thanks.
Hows can I use these in a Calculated Value? Essentially, I want to show one room which each door is related to, I cannot just show either the 'From Room: Number' or the 'To Room Number' as they might be blank in the case of exteral doors. Do I would like to do a Calculated value which says if one is blank, then use the other. Something like: if(From Room: Number="",To Room: Number,From Room: Number) This doesn't work, I get the error 'Improper use of boolean expressions'. What am I doing wrong?? Cheers.
Sorry... from the HELP - Conditional statements can contain numeric values, numeric parameter names, and Yes/No parameters We have no formula operations for text except I believe =.
Well thats disappointing. Its funny, I certainly thing RA is a better product than AutoCAD Architecture but in a few areas, such as this one, RA is way behind. Cheers.
Here is a possible fix... Declare a new variable. number ... If (Number=1, To room,From room)... OK? Not automatic, you will have to set it in the door family - instance fariable assigned in the project to doors.
room names not being picked up in door schedule |
Mon, Apr 21, 2008 at 10:26:48 AM
Door Schedule Problem |
Tue, Sep 21, 2010 at 7:26:12 AM
Door Schedule |
Thu, Feb 20, 2014 at 7:19:42 AM
Customized Door Schedule Needs Help |
Thu, Aug 25, 2011 at 5:53:09 PM
Door Schedule |
Tue, Jun 12, 2007 at 7:29:31 AM
Members: | 2017250 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
