35 Users Online (34 Members):
Forums >> Revit Building >> Technical Support >> Elevation Tags Greyed out and crop region
27 Posts No Rating |
We are working on a project in which we are using design options and when i drop an elevation tag on the floorplan it will only snap to the exterior shell of the model which is link into our revit model for the interior. If i drop the tag it imediatley greys out and i cant adjust anything on it. I go to the view and even the crop region is greyed out. Any ideas would be helpful. Thanks
This is a problem currently in Revit. You can not change views or modify them while in a DO. Just DO edit none. Make sure to set the VG of your view to the DO you want rather than automatic.
I change the VG what do you mean "Just DO edit none" where is this located. Thanks for the help
DO edit none - I meant set Design Option edit to main model. You can't be in the DO if you want to change the view settings.
No Crop Region is greyed out?? |
Fri, Jul 13, 2007 at 9:23:10 AM
Room Tags Outside Crop Region |
Sun, Sep 10, 2006 at 8:05:26 PM
Elevation bugs show up out side of Crop Region on sheets.. Why? |
Wed, Sep 6, 2006 at 7:38:06 PM
Can't get Crop region to be visible in my elevations views |
Tue, Dec 2, 2008 at 8:42:39 PM
Crop Regions, Keynotes & Room Tags |
Sun, Dec 31, 2006 at 7:12:23 PM
Members: | 2056535 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
