77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> cybertecture
Sun, Aug 1, 2010 at 7:51:10 AM | cybertecture
smriti1234
dere is a building in mumbai.. called the cybertecture egg
designed by james law..!!
hw do i make a 3d of dis building...
creating a mass of that shape seems impossible for me..!!
can some 1 plzz make a MASS of it for me..!!
or temme some way of makin it..!!!
hellpppp plzzz...thnx in advance..!!!
Mon, Aug 2, 2010 at 6:12:07 AM | cybertecture
4 Stars: 202 Votes
You must use the "Conceptual Mass" to create that, to create that mass is just a Revolve in that angle then maybe you need to use a couple of Voids, then use the divide the surface, create a new curtain panel pattern like that and that's it...
Simple.
BTW, check this link from Zach Kron : http://buildz.blogspot.com/
Here you can learn how to use the Conceptual mass, Create the panels and so on.... there are several videos about that....
Cheers
Edited on: Mon, Aug 2, 2010 at 6:25:05 AM
Mon, Aug 2, 2010 at 2:35:36 PM | cybertecture
smriti1234
can u just make a mass of it 4 me..!! i tried ...but could nt..!!! m kinda new to revit...jus 1 month of knowing it..11
rest i' kno...
Mon, Aug 2, 2010 at 3:35:25 PM | cybertecture
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Tempting, had I the time.  This seems like a lot to ask of someone from this site, though it would be a fun exercise... but it will also make a great learning experience for you.  Problem solving, thinking of how to using the massing tools to create something so complex... However, you'll see that these mullions in the glass aren't as complex as they seem.  You only need to create one.  And then you can perform a radial array.  And then mirror the radial array.  From the pictures, I can't quite tell if the mullions are on a single plane or not.  But it appears they are, and they might not wrap the egg as much as it appears.  Perhaps exactly 180 degrees.  in which case, I would just slice an extrusion with an egg-shaped void and use the line of that cut as the path for a sweep! (and then do the mirroring/arraying of the sweep)  And then make another glass egg for the curtain panels.     This would be a quick facsimile, for appearances only.  I'll admit I know little about Conceptual Masses, but in-place modeling is handy too.
Tue, Aug 3, 2010 at 4:01:03 AM | cybertecture
4 Stars: 202 Votes
"I'll admit I know little about Conceptual Masses, but in-place modeling is handy too. " - IN-PLACE for that? Radial array then Mirror that radial ??? Good Luck... Again: check that Zach Kron blog, he's a GURU in modelling, watch his videos about Comceptual mass, adaptive components and so on...
Tue, Aug 3, 2010 at 1:08:05 PM | cybertecture
itsmyalterego
4 Stars: 16 Votes
Sure, it'd work!  My firm has very little demand for complex geometries, so it's far down on my list to master.  But I'm confident I could model this with the in-place tools in an hour or two.
Just saying it's much less complex than it appears...
Tue, Aug 3, 2010 at 2:31:32 PM | cybertecture
smriti1234
m using revit 2009...so conceptual massing is nt in it..!!
bt i made the basic structure..!! hav add it...temme how is it..!!!it has just bare essential things in it..!!even de material r nt edited
 i jus did it all by myself...so i m proud,...!!
yaaaayyiieeeee..!!!
p.s. it jus took me less den hlf hr(including rendering time) to do dis..!!! Smile :-)
Tue, Aug 3, 2010 at 2:34:39 PM | cybertecture
Thread Post Kudo! #8
smriti1234
Tue, Aug 3, 2010 at 4:13:21 PM | cybertecture
itsmyalterego
4 Stars: 16 Votes
Looks good!  I gave in to temptation, and tried modeling it a bit.  I gave myself 20 minutes at lunch... I got it wrong, but the principle is sound. the rules for placement of the mullions is still a bit of a mindbender.
Wed, Aug 4, 2010 at 2:07:12 AM | cybertecture
xzavoral
I think its made like this:
Line begins and ends on the same place (at start and end) and on its way it will make full spin over the mass ...
Thu, Sep 30, 2010 at 7:08:48 AM | cybertecture
Kronny
3 Stars: 2 Votes
Air Ventilation  ||  Roof Ventilator || Air Ventilator  || Roof Ventilators
Page generation time: 0.8307
