49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> nested void family
Fri, Jul 30, 2010 at 3:51:54 PM | nested void family
blairmack
Hi
I'm trying to load and array a nested void into another family to create slots in rhs steel posts and regular spacings.  The void family is a generic model and simply a void extrusion size is parameter driven.  The post family is a sweep and when I load the void family it seems to give me no option to cut the post with the void. I can of course create voids in the post family and array them but you get the old message about "too many instances, try nesting a family" which is what I'm trying to do but with not much luck.
Any help would be much appreciated. Cheers.
Blair
blairmack
Sun, Aug 1, 2010 at 10:08:14 AM | nested void family
What you are doing seems rather complicated.  I would think a post is a simple form ... extrusion or whatever - and the voids are created as part of that from and set to cut it.  One void - not multiple voids.  (Remember - you can have multiple shapes in one extrusion (-be it a void or soild) just as long as the closed loops do not cross each other....
O O O could be three voids in one void description.
Sun, Aug 1, 2010 at 3:54:12 PM | nested void family
blairmack
Thanks for that but I'm trying to control the slot size and array length by parameters.  That way this same slot can be used in multiple families I need.
Oh well maybe it's not possible.
Cheers.
blairmack
Mon, Aug 2, 2010 at 3:19:08 PM | nested void family
TKennedy
4 Stars: 7 Votes
Try making the void family using a face based template. Make your void, then make it cut the generic block that represents the host. Then when you load it into your post family, it will ask for a face as a host. It should then cut out whatever it is hosted on.
Wed, Jul 27, 2011 at 2:52:07 PM | nested void family
mccoolj
I have a different but related issue where I have made a void extrusion on a face-based template, and it loads up fine into my family and cuts the host correctly, but I have an object directly underneath the void's host that I would like to also get cut by the void. Is that possible? The void shows as extending through the 2 objects, but it doesn't cut the lower one. I tried using Cut Geometry tool, but it won't recognize the void for me to pick it (presumably because it's inside a nested array?). Any ideas?
Jason
Use Nested Void Family to Cut Host?
Sat, May 28, 2011 at 10:39:48 AM
Nested Void Problems on Shared Families (doesnt cut nested family if its shared)
Tue, May 10, 2016 at 8:39:49 AM
Void cut in nested casework family
Tue, Oct 15, 2013 at 12:46:49 PM
Nested void geometry doesn't cut host solid
Mon, Dec 6, 2010 at 3:18:43 PM
Void cutting nested families [ 1 2 ]
Mon, Oct 21, 2013 at 10:42:49 AM
17
Page generation time: 1.1045
