56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Line in a 3D view
Fri, Jul 30, 2010 at 1:54:21 PM | Line in a 3D view
HerSun
As you can see in two images I attach, every line of this building is visible for some reason. I checked 'Shading with edge', but still like this. It looks like a transparent building. Please let me know how I can solve this problem.
Edited on: Fri, Jul 30, 2010 at 1:55:09 PM
Fri, Jul 30, 2010 at 2:15:13 PM | Line in a 3D view
4 Stars: 203 Votes
delete that 3D view and create a new one.
What version, 2010?
What graphic card do you have?
Fri, Jul 30, 2010 at 3:03:39 PM | Line in a 3D view
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
You can also check your Visibility Setting (VV) for those transparent elements.
 "If you tell the truth, you don't have to remember anything"
Fri, Jul 30, 2010 at 3:54:39 PM | Line in a 3D view
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
This does look like some elements have been set with a transparent override however, some of the hidden/obscured edges and some of the colors should really not be displaying if that is the case...just looks a bit off IMHO.
You could test this theory rather quickly by setting you visaul style to shaded or realistic.
If all those lines dissapear, it is more than likely that the elements have an override...if not, I would do what Ty suggested if you have not done so already.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Hidden Line View [ 1 2 ]
Wed, Oct 6, 2010 at 2:49:03 AM
22
line style in plan view
Thu, Mar 4, 2004 at 12:47:44 PM
View Title Extension line
Mon, Apr 23, 2007 at 6:38:23 PM
Section line disappears from plan when section view is placed on same sheet
Thu, Sep 4, 2014 at 7:46:21 AM
Deleting View Title Extension Line.
Thu, Dec 27, 2007 at 10:06:06 AM
Page generation time: 1.7346
