120 Users Online (117 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> printing contours
Thu, Jul 29, 2010 at 5:14:48 PM | printing contours
Tphill
I just but the finishing touches on a site drainage plan and a erosion control plan. Hit the print button and walk to the plotter (HP800) and the new contours are not plotting, the existing one are there with the both solid and hidden (modified areas). Any reason why the new contours will not print? I'm using RAC 2010.
Tom Phillips
Architectural CAD Manager & Computer Admin.
Titan Construction & Engineering Services, Inc.
Fri, Jul 30, 2010 at 1:06:00 PM | printing contours
If it shows on the screen, then it should be printing.   Try printing to a PDF.  Something may be wrong with your print driver.
Fri, Jul 30, 2010 at 2:19:01 PM | printing contours
Tphill
A few hours after creating this post, and with lots of pondering, trail and error, including creating a pdf file (with the same results as the plotter), I finally figured it out. The problem was that the existing topo needed to a graphic override to "Transparent". The new topo design had several swales that cut into the existing, thus placing the these new swales (topo lines) below the existing topo. With Model Graphic Style set to "Hidden Line" the existing topo was hiding the new. Strangely I could see the new swale topos on my screen and just figured it would print.?? So problem solved for now. One for the memory bank.
Tom Phillips
Smoothing contours...
Tue, Feb 17, 2009 at 8:43:15 AM
contours
Mon, Apr 24, 2006 at 5:16:05 AM
New vs. Existing Contours [ 1 2 ]
Thu, Jun 28, 2012 at 2:27:21 PM
16
Topo surface Control from imported contours
Mon, Feb 17, 2014 at 7:28:50 AM
Changing the amount of contours between intervals.
Tue, Sep 20, 2011 at 3:00:41 PM
Page generation time: 3.0101
