143 Users Online (141 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> revit multipage printing
Wed, Jul 28, 2010 at 2:33:20 PM | revit multipage printing
jennicadd
All computers in our office have adobe acrobat professional.
When we try to print as a pdf and select combine multiple selected views/sheets into a single file, it will combine them, but it combines it as many times as we have sheets.
for example, we have 17 sheets.  When we choose "combine multiple selected views/sheets into a single file" the file combines all 17 sheets, but it creates the combined file 17 different times (just like if I was doing each page seaparately, the only difference is that it is the combined file).
thanks for any help!
Jennifer
Wed, Jul 28, 2010 at 2:34:05 PM | revit multipage printing
jennicadd
also.. this is in Revit 2010.
Wed, Jul 28, 2010 at 2:59:28 PM | revit multipage printing
3.5 Stars: 396 Votes
Make sure your number of copies is set to 1.  That is not the number of sheets.
If that is not your poroblem, then there is something in your properties setup for the PDF writer.
Wed, Jul 28, 2010 at 8:32:48 PM | revit multipage printing
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
also you can print them all separate, then combine them with acrobat pro... veeeery easy
Thu, Jul 29, 2010 at 7:17:28 AM | revit multipage printing
Nasty ... doing the combined PDF out of Revit is far easier than printing each one and combining later.
Mon, Aug 2, 2010 at 8:58:09 AM | revit multipage printing
psmeisje
I'm having the same problem in revit 2011. When i wanted to make a 12-page pdf in revit, i got 12 pdf's, all containing the same 12 pages.
The number of copies was set to 1. And i don't know if it's a  property of pdf writer. Sometimes it works fine, sometimes i get multiple pdf's without changing any properties in the pdf writer.
I'm using adobe acrobat standard
Mon, Aug 2, 2010 at 9:17:17 AM | revit multipage printing
We have been using CutePDF for several years and have never had a problem.. Revit 8,9,10,11.
I would look at you printer driver.
Printing Query
Wed, May 23, 2012 at 7:54:08 AM
Printing Problems Revit 2012
Wed, May 16, 2012 at 7:31:01 AM
printing press
Wed, Dec 29, 2010 at 11:28:44 AM
Printing Lighting Plans in Revit MEP
Mon, Mar 14, 2011 at 9:20:35 AM
Fill Region set to Transparent but printing Opaque [ 1 2 ]
Sat, Jan 26, 2019 at 12:16:15 AM
18
Page generation time: 1.8147
