122 Users Online (121 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Error when inserting views from a Revit file (version 2011).
Tue, Jul 27, 2010 at 4:28:46 PM | Error when inserting views from a Revit file (version 2011).
JTG76
Hello all.
     I am having trouble with the "Insert Views from File" command in Revit 2011. I keep getting an error message that reads, "Unable to insert objects into file," or something to that effect.
     But here's the weird part: After you try it three or four times, it will work. This is obviously very aggravating and time consuming. Does anyone know what might be causing this and, more to the point, what I can do to make it stop?
     Thanks!
-Jason
Wed, Jul 28, 2010 at 7:00:06 AM | Error when inserting views from a Revit file (version 2011).
Obviously these are 2D drafting views.   What kind of elements do they contain?  Any CAD inserts?  Any CAD inserts in families?
Wed, Jul 28, 2010 at 3:58:58 PM | Error when inserting views from a Revit file (version 2011).
shaverjeff
I have run across this on past releases of Revit Structure (2009/2010).
In my case the views for insert were 2d drafting views containing only native revit families. I was able to track down the cause to a specific custom family. This was a type based detail component family (not line based) that contained a nested "shared" linebased detail component. If I recall the project I was inserting into already contained the nested linebased family but it was not the shared version. (note the nested shared version was outdated)
Interestingly removing only those detail components allowed me to insert the details without issue.
 Shame on the dialog for being so vague Winking
Thu, Nov 18, 2010 at 3:08:33 PM | Error when inserting views from a Revit file (version 2011).
markuspirker
I'm having the same issue and no clue what to do about it.  I have a typical wall section that was created inside revit as a drafting view and now I can't import it. grrrrrr.
Thu, Nov 18, 2010 at 3:17:03 PM | Error when inserting views from a Revit file (version 2011).
You say wall section but is it a drafting view or was it cut as a model view and model elements are tutned off?
Mon, Nov 29, 2010 at 1:22:25 PM | Error when inserting views from a Revit file (version 2011).
leothelionator
I just ran into the same problem and was able to isolate the exact issue.  The views that refused to import were views that were attempting to display outdated and missing CAD file links.  I corrected the problem by removing the CAD file links Cryingfrom Manage tab/Manage Links) and the sheet imported just fine!
'unable to copy elements from file' error in inserting a saved view
Wed, Jul 25, 2012 at 10:16:56 AM
Reverted to demo version after fixing error problem 2011
Sat, Sep 4, 2010 at 6:42:25 PM
Error when inserting drafting view from file "Unable to copy elements from file"
Thu, Apr 1, 2010 at 5:06:40 PM
Autocad 2011 Solid To Revit 2011 Mass floor error
Mon, Feb 28, 2011 at 7:20:11 AM
error message trying to download a family into revit 2011
Fri, Oct 15, 2010 at 5:07:53 PM
Page generation time: 3.5478
