53 Users Online (52 Members):
Forums >> Revit Structure >> Technical Support >> Wall Foundation
Is it possible to pull a Wall Foundation back from the end of a wall. I can pull it past the end of the wall, but not the other way. Please refer to my attached picture for reference. I would like the wall footing to stop at the dashed line with the note "To Here." Thanks in advance.
I use Autodesk Revit Structure 2011 My songs: http://nkat.newgrounds.com |
So the wall has no foundation beyond that point... interesting....skyhook? I have yet to see a skyhook work. Split the wall vertically and you should be able to end the foundation. You can still join the walls so the vertical line goes away.
There is an existing building at that point where the foundation will end. Most likely we will scab onto the existing footing for the wall support. I figured splitting the wall was the way to go. Thanks for your response.
Split Region Wall Foundation Issues |
Wed, Jun 1, 2011 at 5:36:25 PM
foundation wall tag |
Wed, Jul 22, 2015 at 1:22:24 PM
WALL FOUNDATION CORNER |
Tue, May 5, 2015 at 10:17:12 AM
Foundation Wall Family Edit |
Mon, Apr 20, 2009 at 5:53:01 PM
Wall Footings and Foundation extrusions |
Wed, Jun 8, 2016 at 7:55:54 AM
Members: | 2067249 | Objects: | 23086 | Forum Posts: | 152277 | Job Listings: | 3 |
