53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Roof Rafters
Fri, Jul 23, 2010 at 11:53:47 AM | Roof Rafters
Revitizer
Hello,
 Thanks for the response.
In regards to the issue of adding rafters to the roof, I was directed to the link  http://www.revitcity.com/forums.php?action=viewthread&thread_id=10882 , I loaded a wooden framing material from the Strutural folder (as indicated in the previous thread) but I am not able to add it as rafter. How can I possibly accomplish this.
 Instaed I loaded a detail component- Roght cut lumber and used it to show/fake it as rafters in a section view....not at all sure if that would be aright thing to do.
Any suggestion would be highly apprecitaed.
Thanks
Thu, Jul 29, 2010 at 7:06:03 PM | Roof Rafters
robinballew
robinballew Avatar
3 Stars: 4 Votes
What I would do is use Beam System. I would define the working plane as the roof surface. Load beams, wood, steel, or what ever. It just has to be a beam. If you don't know how to use the beam system it is just like defining a floor with a direction for the span. Works good. Let me know if that helps.
BallewDesigns.com
drawing angled roof rafters
Tue, Aug 18, 2009 at 11:53:18 AM
Roof Rafters
Tue, Apr 8, 2008 at 2:41:46 PM
Custom rafters/roofing Revit 2012
Wed, Oct 9, 2013 at 8:31:56 PM
How to make a roof consisting of rafters and trusses?
Mon, Feb 1, 2010 at 10:46:28 AM
Exposed Rafters- Revit 2012
Thu, Aug 9, 2012 at 9:18:11 AM
Page generation time: 1.0006
