Forums >> Revit Building >> Technical Support >> Revit 8.1 Service Pack
I use 8.1 and in the midst of one of my average 10 crashes of this *&$#%& program on a brand new workstation, I noticed a link to the Autodesk site for a service pack for revit 8.1 (below). The text seems to imply this will adress crash issues. However, when one cliks the line "Updates and Service Packs->Revit 8.1", nothing happens. I have downloaded the line that says "Updates and Service Packs->Revit 8" and when it runs (with the disk in the CD as req'd) the message appears "the expeced Autodesk product could not be located on your computer".
Has anyone been able to find this service pak for 8.1 and make it work?
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=3770209#section1
Revit comes in builds: the current build is 20050914_0100
Rarely is the CD build ever current for very long and it is always a good idea to check this site if you are experiencing issues to see if you have the latest build:
http://revit.autodesk.com/Building/8.1/common/download.asp?en-us
HTH.
There is no service pack for Revit 8.1....only for Revit SERIES 8.1 (which comes with AutoCAD). I think you have downloaded the service pack for Series, and thus the install package cannot find your Revit 8.1, because it's looking for series.
Beyond that, I highly doubt your problems are related to Revit software. Your culprit is probably your #@%$% brand new workstation. 99% of the time, crashes in Revit are due to video card driver issues. You need to go to your computer manufacturers's website and download the latest drivers for your video card. If that does bot solve your problem, contact Revit Support right away and they can tell you what driver conflict is causing your crashes.
Another thing to try first: Turn off Hardware Acceleration and Open GL from Settings in Revit, and turn Hardward Acceleration down/off inside the video control panel of your computer.
My new workstation was purchased specifically because I assumed my old workstation was in need of an update to cure my dozen a day crashes in Revit 8.1 on the old workstation. 2 workstations, same problem. Revit 8.1.
Here is the new workstation:
Base Unit:
Dell Precision 670 Mini-Tower3.40 GHz,XEON Processor w/ 2MB L2 Cache,800FSB (221-7979)
Processor:
2nd Processor, 3.40GHz,XEON 800FSB,2MB L2 Cache, Dell Precision 670 (311-4854)
Memory:
3GB, DDR2 ECC SDRAM Memory, 400MHz, 2X512MB + 2X1GB, Dell Precision 470/670 Factory Inst (310-4969)
Keyboard:
Entry Level, USB, No Hot Keys,Dell (320-3811)
Monitor:
Monitor Option-None (320-3316)
Video Card:
nVidia,Quadro FX 1400,128MB dual VGA or DVI, Graphics CardDell Precision 370/470/670 (320-4175)
Hard Drive:
160GB Serial ATA 7200RPM Hard Drive with DataBurst Cache, NON-RAID,Precision 470/670 (341-1139)
Hard Drive Controller:
C1- All SATA Hard Drives, Non-RAID for 1 Hard Drive, Precision 670 (341-1113)
Floppy Disk Drive:
No Floppy Drive, Precision Workstation 670, Factory Install (341-1436)
Operating System:
WINDOWS XP PRO SP2, with MediaDell Precision,English Factory Install (420-4860)
Mouse:
Dell USB 2-Button Entry Mouse Mouse with Scroll for Precision Workstations (310-5203)
NIC:
NTFS File System,Factory Install (420-3699)
CD-ROM or DVD-ROM Drive:
48XCDRW AND 16XDVD+/-RW w/Sonic Digital Media and CyberLink PowerDVD Dell Precision 470/670 (313-3381)
Revit 2010 Service Pack 1 |
Tue, Sep 29, 2009 at 9:28:38 AM
Service pack for Revit 2010 |
Sat, Jun 27, 2009 at 7:13:14 AM
Service Pack 3 question |
Wed, Dec 12, 2007 at 11:39:20 AM
Service Pack Won't Install Revit Architecture 2009 |
Sat, May 29, 2010 at 5:18:39 AM
Fill Patterns |
Mon, May 4, 2015 at 12:23:18 PM
Members: | 2042216 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
