38 Users Online (36 Members):
Forums >> Revit Building >> Technical Support >> Indefinate Loop in Operation
5 Posts No Rating |
We are trying to do some basic level manipulation of walls in a floor plan view, moving, aligning, trimming,etc. Revit is getting caught up when executing the command and the "regenerating" progress bar stops at "0 %" and never progresses. We have experienced this on (2) different desktops, but both starting from the same view. The only unique setting on this view is that we have shading turned on. Anyone else seen this?
It may be that it really has not stopped. Many times, Revit will not show any progress but it is still working. And sometimes, that can be a long time. Shading and shadows are a problem, especially if you are manipulating the view ... rotating - panning. In some models, we have to turn shading and shadows off while manipulating the view.
CLOSED LOOP? |
Mon, Dec 30, 2019 at 2:55:23 PM
Door parameter: IFC Parameters: Operation, how can I use it? |
Fri, Oct 2, 2009 at 8:53:25 AM
Parapet Profile Closed Loop Error |
Fri, Mar 8, 2013 at 12:12:04 PM
Casement Window Operation |
Thu, Dec 22, 2016 at 4:46:30 PM
Revit 2009 window operation |
Thu, May 22, 2008 at 7:00:55 PM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
