Forums >> Community >> Newbies >> Newbie questions
9 Posts No Rating |
I am VERY new to the Revit world, but not to 3D or to AutoCAD. From some of you gurus - where would I start to build my revit families up? I noticed on Kohler that they had QUITE a few revit families, but what are some other resources? Can I import some from SketchUp? How does that work? Is there some other advice that you might have to make my transition easier? I would also like to use my own elevation markers , etc over the "standard" ones that come with Revit. Can I use those? We did not want our drawings to look TOO different than what we are used to in AutoCAD. Do you have some advice on that? All of this is VERY much appreciated!! Angela Revit Architecture 2011
First of all: Welcome to Revit's World, I work in Autocad since 1989/90 so i have a long way in CAD too. "where would I start to build my revit families up?" - i think you should start from the "Tutorials": http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14844953&linkID=9243097 "I noticed on Kohler that they had QUITE a few revit families, but what are some other resources?" - there are several sites where you can download families like www.Revitcity.com http://www.revitcomponents.blogspot.com/ http://www.greenheck.com/drawings/ http://www.littledetailscount.com/ http://www.familit.com/?mod=2 and you have much more if you search "Can I import some from SketchUp? How does that work?" - Yes you can, here in "Forums" search for "Sketchup" you will find lots of threads about that. "Is there some other advice that you might have to make my transition easier?" - Yes, learn the most you can every day. "I would also like to use my own elevation markers , etc over the "standard" ones that come with Revit. Can I use those?" - You can create your owns, you have templates to do that: New > Family > Annotations "We did not want our drawings to look TOO different than what we are used to in AutoCAD. Do you have some advice on that?" - With time you will learn.... Good Luck...
Edited on: Wed, Jul 21, 2010 at 10:58:15 AM
For Revit items from manufactureres, use the AutoDESK SEEK site.
9 Posts No Rating |
What is the Autodesk SEEK site? I have not heard of this before...
http://seek.autodesk.com/
9 Posts No Rating |
Thank you so much!! This is a great start!!
9 Posts No Rating |
Ok a little of subject here, but where do I find the "activate dimensions" button to show temporary dimensions. I am confused
From your HELP menu, use it...
9 Posts No Rating |
HAHAHA. I had looked that up but the button never appeared. After selecting another wall - I realized that temporary dimensions are on and that I cannot use the dimensions because the wall was anchored to an exterior wall. Now I think I need to go to bed LOL
Multiple Newbie Questions |
Mon, Sep 23, 2013 at 8:47:23 AM
yet another revit newbie....with alot of questions |
Mon, Jan 14, 2013 at 8:08:21 AM
newbie here, questions. |
Sun, Jan 18, 2009 at 10:14:42 AM
Complete Newbie Questions |
Wed, Jun 20, 2012 at 2:39:58 PM
hello newbie here and questions about rendering |
Fri, Jul 30, 2010 at 3:47:38 PM
Members: | 2030682 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
