Forums >> Revit Building >> Technical Support >> Changes in Elevation levels!!! (Revit 2009)
Hi everyone, I'm working on a renovation/addition project and when we first started out we didn't have the civil and survey, so we based our elevation marks on the existing drawings. Lets say that was in the 400'. Now we are at the end of the project and we noticed that the civil numbers are in the 900's!!!! How do we change this on our drawings without messing up our sections, elevations, and details? When I tried to change the numbers manually, it moved all the walls attached to it, 500'! Help, I'm freaking out here, lol.
Your HELP menu is a GREAT BOOK.... You must use Coordinates > Specify Coordinates at a point
Thank you :-). I looked in the Help Menu and couldn't find what I was looking before I came up here. By doing this, does it change the elevation numbers so it will show up correctly in all my sections, etc?
Why don't you try it?
Lol, I did but it's not changing the numbers on the level. It shows the right number under the properties for Specify/Report Coordinates. Please, see attached.
Select the Elevation line, go to properties > edit Type then change the "Elevation Base" project to Shared
Nevermind!!!! I went into the properties of the Levels and changed the elevation base from Project to shared. Thanks again!
Elevation Levels Mess |
Thu, Jun 26, 2008 at 11:53:13 AM
Revit 2009.1 Bind Revit Link Does any one know if 2009 has improved this? |
Tue, Oct 14, 2008 at 3:36:56 PM
Toposurface is drawn at the wrong elevation relative to levels |
Fri, Aug 4, 2017 at 12:09:48 PM
Cannot see my floor levels |
Tue, Mar 10, 2015 at 12:42:26 PM
walls on different levels not even |
Tue, Sep 9, 2008 at 2:14:45 AM
Members: | 2057170 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
