Forums >> Revit Building >> Technical Support >> adding radius edge to floor slab
17 Posts No Rating |
What's the easiest method of adding a radius edge to top of floor slab. Sweep? Slab edge? Adding profile? I'm actually designing a table and the top needs a 1/8" radius edge. I used walls for the verticle components and a floor slab for the top and bottom. I've created my profile, but not sure if it should be a generic or hosted, so I created and saved both with their respective names. Revit 2010
This one i can't understand. " I'm actually designing a table and the top needs a 1/8" radius edge. I used walls for the verticle components and a floor slab for the top and bottom. " You are creating a table with floors and walls???  Images please....
its the mission style hexagon between two chairs Using walls and floors was my first inclination. What's your recommendation?
You are really creating a table with walls and floors, i can't believe that.... You have "Templates" (families) to create what you want in Revit Go to Create > New > Family then choose "Metric/Imperial Furniture" to create that table...
Need help creating a sloped slab with Radius Edge |
Tue, May 2, 2006 at 5:23:52 PM
floor slab edge |
Fri, Aug 22, 2008 at 3:31:34 AM
Floor slab edge not joining right REV2008 |
Tue, Aug 14, 2007 at 3:37:07 AM
Slab Edge Profile... Except Up... |
Wed, Nov 11, 2009 at 7:00:24 PM
Creating slab edge... |
Tue, Nov 4, 2008 at 3:36:02 PM
Members: | 2104176 | Objects: | 23178 | Forum Posts: | 152299 | Job Listings: | 3 |
