61 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> change draw order - make lines and images show on top of components
Thu, Mar 18, 2004 at 2:58:11 PM | change draw order - make lines and images show on top of components
dakota
how do you control walls and components so they allow lines and images to show through?
Thu, Mar 18, 2004 at 4:52:55 PM | RE: change draw order - make lines and images show on top of components
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I have also had this problem with elevations...
Hiroshi Jacobs
Fri, Jul 15, 2005 at 9:54:24 AM | RE: change draw order - make lines and images show on top of components
oceanmandy
I also have been unable to find a solution for getting simple things like images maped into Elevations. This is commonly done in CAD - like adding logos to elevations or signs and such- There seems to be no way to do so in Revit. I think it is something the programers never thought of.
Fri, Jul 15, 2005 at 7:35:46 PM | RE: change draw order - make lines and images show on top of components
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If your doing it for rendering purposes used decals. Otherwise, yes its a bit of a bugger. The only way to get an image to display on top of any model element in revit is to create a new annotation symbol and import the image into that then load the family in. Be sure to link the height and width parameters so you can adjust the size in the project... HTH.
Thu, Aug 16, 2007 at 10:42:11 AM | change draw order - make lines and images show on top of components
JHanby
3.5 Stars: 3 Votes
Mr. Spot,
Will this work in a titleblock situation?  We are trying to make a presentation titleblock that has a solid black fill with company logos on top of the black fill.  In the titleblock family itself, we have set the images to foreground on top of the solid black fill.  However when we load the titleblock into a project file the images don't show up.  Using version 9.1
Draw Order: components that are gray blocking my black wall lines??? help??
Fri, Sep 7, 2007 at 4:09:13 PM
draw order
Wed, Aug 20, 2008 at 8:26:34 AM
Detail Components with Demo Objects
Tue, Dec 30, 2008 at 4:34:30 PM
Draw Order in Family Editor
Wed, Aug 28, 2013 at 3:07:32 PM
Draw Order for Revit?
Mon, Jun 21, 2010 at 2:49:32 PM
Page generation time: 2.2841
