123 Users Online (122 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Curtain Wall runnning bond pattern
Tue, Jul 20, 2010 at 4:22:18 PM | Curtain wall running bond pattern
cgruwell00
Is there a way to automate the creation of a running bond pattern on a curtain wall?  Of course I can create the horizontial grid lines in the curtain wall type.  The problem is the vertical grid lines are staggard.  Is there some kind of formula I can use to create the staggard grid lines?
Edited on: Tue, Jul 20, 2010 at 4:23:43 PM
Fri, Jul 23, 2010 at 7:08:58 AM | Curtain Wall runnning bond pattern
4 Stars: 203 Votes
Can you apply some images to figured out what you really want to do?
Fri, Jul 23, 2010 at 7:34:05 AM | Curtain Wall runnning bond pattern
Just place the full grid, then edit it to drop every other section in both directions.
Fri, Jul 23, 2010 at 7:54:30 AM | Curtain Wall runnning bond pattern
cgruwell00
Do I have to manually select and remove each grid line that I do want.  If so then I have thousands of gridlines to remove.  I am looking for a much quicker way to do this.  If you haven’t figured it out yet, I am trying to layout brick using a curtain wall.  I cannot use a simple hatch pattern because I have to count every brick and also give a size and total for every cut brick.  Let me know if you have any other ideas on how to accomplish this.
Thu, Mar 24, 2011 at 11:24:29 AM | Curtain Wall runnning bond pattern
TimothyLiv
All,
Has there been any further discussions on this topic.  I work for a stone wall cladding company and this is our holy grail. we have running bond projects all the time and adjusting / adding / deleting the mullions is a bit cumbersome for a newbie.
I read "Just place the full grid, then edit it to drop every other section in both directions" from WWHub. Could you explain this further.
Thank you,
Timothy
Thu, Mar 24, 2011 at 12:17:03 PM | Curtain Wall runnning bond pattern
Two ways... edit the grid pattern or stack one CW on another.
BTW... Once you have it edited in one project....just copy paste it into the next one.
Thu, Mar 24, 2011 at 1:01:29 PM | Curtain Wall runnning bond pattern
TimothyLiv
Thank you for the quick response.  Can I use Reference planes to *move* the mullions? any tips on that route?
RE: Stacking one CW on another, would you group them to ease moving / coping ? My current project is 16 courses high.
Thanks again.
Fri, Nov 4, 2011 at 11:34:18 PM | Curtain Wall runnning bond pattern
MHCheng
1 Stars: 1 Votes
you can try creating 2 CWs. One for the horizontal systme and one for the vertical system. You then use the vertical system as a a panel on the horizontal system. you can offset every other instance of the panel to create a running bond.
Custom Running Bond Brick Pattern
Fri, Aug 26, 2016 at 2:38:25 PM
Curatin Wall Limitations
Thu, Aug 6, 2009 at 9:45:27 AM
Curtain wall panels behavior....what gives?
Fri, Jul 22, 2011 at 3:34:54 PM
Vertical Reveals for Running Bond Pattern
Thu, Sep 3, 2009 at 8:20:46 AM
4’ x 8’ running bond hatch.
Thu, May 8, 2008 at 7:02:50 AM
Page generation time: 8.6690
