Forums >> Revit Building >> Technical Support >> Trouble with sky for rendering
1 Posts No Rating |
I am using Architecutre 2011 and I cannot get sky to show up in my rendering. I have selected sky w/few clouds from the backround part of the rendering menu but it still renders it as a solid color. I have tried a few other things but still cannot get it to work out. If you have any suggestions or solutions then fire away. Thanks!
You are talking about that grey color in my image right? that's the "Horizont line", to avoid that or you have a huge site or you can change the backgroud to "Image" then select one image to your "Sky" (last 2 images)
4 Posts No Rating |
I am having the same issues. The rendering is just showing the gray background of what's outside of the siteplan/property lines. I've changed the sky settings to all different settings. I tried the above recommended information, but unfortunately I do not have an "image" option. It only goes to "color" as my last choice. This is in Revit Architecture 2010. Thanks for any additional help! Chris
To 2010 look at the bottom of this page, you will see similar thread issues like this but take a look here: http://www.revitcity.com/forums.php?action=viewthread&thread_id=17655
4 Posts No Rating |
Thanks Typhoon for that link! Chris
Rendering Questions re Sky |
Tue, Sep 19, 2006 at 4:34:00 PM
Rendering in Revit 2009 [ 1 2 ] |
Thu, Dec 31, 2009 at 10:41:31 AM
19
Rendering with no sky. |
Sat, Mar 21, 2009 at 2:49:59 PM
11
Revit 2010 rendering & sky options |
Thu, Dec 8, 2011 at 1:08:33 PM
No sky in rendering! HELP |
Fri, Apr 29, 2011 at 10:18:29 AM
Members: | 2116504 | Objects: | 23196 | Forum Posts: | 152298 | Job Listings: | 3 |
