71 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Objects showing up in elevations where I don't want them...
Tue, Jul 20, 2010 at 10:21:04 AM | Objects showing up in elevations where I don't want them...
Thehiddenthought
Thehiddenthought Avatar
So I've created this 3 Part Grab Bar for my tub and I'm having trouble with the elevations- it is showing a bit too much like what is in the "back" of the cut line.  Take a look at the image highlighted in teal, it shows the grab bars at either end of the tub, and I want only one of them in each view.  Also, I've attached the family- if anyone can figure out how to fix this.  Thanks!
Thehiddenthought
Tue, Jul 20, 2010 at 11:12:48 AM | Objects showing up in elevations where I don't want them...
If all the grab bars are in that one family, then they will all show.  Only some family types are cuttable, otherwise the entire family shows when any part of it is cut by the view.  You can find which families are cuttable in your help.
MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE
Fri, Aug 11, 2006 at 1:18:16 PM
Building Not Showing in North/West Elevations
Mon, Aug 18, 2014 at 11:44:39 AM
Beams not showing in Elevations
Sat, Jul 18, 2009 at 3:13:16 AM
Floor pattern showing through objects
Tue, Apr 1, 2014 at 10:49:07 AM
Families that are "behind" cut showing up in interior elevations.
Wed, Jan 23, 2008 at 10:50:17 AM
Page generation time: 1.1177
