28 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> SCALING JPEGS FOR RENDER SCENES
HI can anyone give an idiot proof example as to how to scale down the accurender for render scenes. I have stone walls on a building and the images available are too big when it comes to render scenes,
I have tried mapping and scaling and run a test render scene but the image stays the same size - any advice please??
Thanks
Refer to your other post.
Will
Not sure if you have found same potential bug as me ? I found that once I had set up a scene and produced the first render, if I wanted to change any render materials, light settings etc, I would always get the same render as b4. I found that I had to create a new scene, same camera position etc and then produce new render for changes to occur. I brought this up at a user group meeting a while ago and they had not come across it till they tried it. No solution was fothcoming at that time.
If this not relevant 2 u, sorry.
Texture - adding new into matrial library from picture |
Mon, Oct 10, 2005 at 5:51:42 AM
Using JPEGS inside revit and then...iluminate them! |
Fri, May 24, 2013 at 6:19:16 AM
jpegs showing up black |
Fri, Mar 26, 2010 at 10:41:16 AM
Material scaling in cloud render |
Wed, Oct 9, 2013 at 1:26:29 PM
jpegs wont show up on plot |
Tue, Jan 15, 2008 at 12:09:04 PM
Members: | 2056327 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
