57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Need assistance with a roof ridge line issue
Fri, Jul 16, 2010 at 9:36:11 AM | Need assistance with a roof ridge line issue
jfmonod
 Hi.
 The attached image says it all I think. The roof that's there is what Revit does and the red lines show what I actually want. I'm in RAC 2011.
All the slopes, eave heights and overhangs are constant all the way around.
Any help with this would be greatly appreciated.
JF
Fri, Jul 16, 2010 at 9:38:11 AM | Need assistance with a roof ridge line issue
jfmonod
And of course the image didn't attach. Lets try that again.
Fri, Jul 16, 2010 at 12:53:26 PM | Need assistance with a roof ridge line issue
TKennedy
4 Stars: 7 Votes
Can you post a screenshot of your roof sketch?
Fri, Jul 16, 2010 at 2:38:07 PM | Need assistance with a roof ridge line issue
4 Stars: 202 Votes
Just like TKennedy says: show us some screenshots of your roof sketch please.
Mon, Jul 19, 2010 at 8:13:20 AM | Need assistance with a roof ridge line issue
jfmonod
 Ok. As requested here's a shot of the roof sketch. All overhangs are 2'-0", all slopes are 5/12. The walls are stacked walls so all the lines were drawn using "pick lines" instead of the walls. This is also the case at the column locations out front. All eaves are subsequently aligned using the "align eaves by height" option.
I see that you got it to work Typhoon. I'd love to know how : )
 Thanks
JF
Mon, Jul 19, 2010 at 9:30:19 AM | Need assistance with a roof ridge line issue
4 Stars: 202 Votes
You can't create that in one piece, you must create that in two different roofs like you can see in my images attached....
Mon, Jul 19, 2010 at 10:02:41 AM | Need assistance with a roof ridge line issue
jfmonod
 Ok. Got it.  Thanks.
Roof Ridge
Tue, May 9, 2006 at 1:15:59 PM
Can a sweep be applied to a roof ridge to model ridge capping??
Mon, Feb 4, 2008 at 11:01:27 AM
11
ridge control on a sloped roof
Tue, Jul 3, 2012 at 12:18:42 PM
off center roof ridge
Wed, Jun 3, 2009 at 12:37:25 PM
Inserting a sklight on a ridge.
Mon, Jul 19, 2004 at 9:48:15 AM
Page generation time: 2.4840
