75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> A required resource was unavailable. Crash on 32 bit Operating System
Wed, Jul 14, 2010 at 6:12:03 AM | A required resource was unavailable. Crash on 32 bit Operating System
4 Stars: 201 Votes
Published date: 2010-Jul-12 ID: TS15374167
Applies to:
Autodesk® Revit® Architecture 2011
Autodesk® Revit® MEP 2011
Autodesk® Revit® Structure 2011
Issue
You were working in a Autodesk Revit 2011 product and the product crashed with an error message. This crash occurs when working on a 32 bit system. You received a Customer Error Report dialog following the crash. The two most common messages are:
A fatal error has occurred.  The application will be terminated.  You have the opportunity to save recovery files for all of your changed projects. Would you like to save a recovery file?
Solution
The following actions can reduce the frequency of these errors:
  1. Verify that your graphic card and driver is listed as Supported onGraphics Hardware List.
  2. Switch to a 64 bit operating system and utilize a 64 bit Revit 2011 Product.
If this behavior does occur, please submit a Customer Error Report containing an e-mail address along with a description of the workflow leading up to the crash.  For additional information on the error report process, please see the link below:Customer Error Reporting (CER)For additional assistance please log a support request through Subscription Center or contact your reseller.
 Here the original post:  http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15374167&linkID=9243099&CMP=OTC-RSSSUP01
Edited on: Wed, Jul 14, 2010 at 6:14:34 AM
Got questions about moving to 64 bit
Wed, Jun 10, 2009 at 11:05:38 AM
Revit files won't open in 2011 on 64-bit operating system
Wed, Jul 14, 2010 at 9:22:39 AM
windows XP Professional x 64 bit
Wed, Sep 27, 2006 at 12:39:51 PM
2010 and vista 32-bit
Thu, May 7, 2009 at 10:40:48 PM
11
64 bit screensaver crash
Fri, Dec 18, 2009 at 9:17:00 AM
Page generation time: 7.0407
