46 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> KeyboardShortcuts.xml file
Tue, Jul 13, 2010 at 4:38:15 PM | KeyboardShortcuts.xml file
amandaholly
I am in revit 2011.  On a 64-bit machine with Vista.  I followed the link from Autodesk to find the Keyboard shortcut test file.  It's not there.  Any ideas where this is found? I don't see anything on the User Interface that would tell me where this file is either.
Here is were I attempted to find it.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14636444&linkID=9243099
 Thanks!
Mandy
Imported xml file doens't appear
Wed, May 20, 2020 at 9:31:14 AM
import xml files
Wed, Jan 5, 2011 at 10:40:41 PM
Exported Keyboard Shortcut file is .xml format - can't open in Excel
Fri, Jan 13, 2012 at 11:41:37 AM
keyboardshortcuts.txt revisited.
Fri, Nov 23, 2007 at 11:51:09 AM
Revit Families with XML files
Thu, Nov 8, 2012 at 7:00:31 AM
Page generation time: 26.2237
