39 Users Online (38 Members):
Forums >> Community >> Newbies >> Wall with geometric cut outs
2 Posts No Rating |
Hi I am really new to Revit, (just learned over the weekend). I am trying to work on a project in which I have designed a feature wall in the space that will have geometric (mostly triangular-shaped) cutouts that will be see through. How on earth do I accomplish this in Revit... Please help!!! On a time constraint to get this done. If anyone is willing to give step-by-step instructions, I would really appreciate that. Mel
Edit the wall then you can change the shape like you can see in the images attached...
2 Posts No Rating |
Typhoon, Thank you.....one question. What view are you in to see the wall straight on? Is that when you initially select to make a wall or is it (the first one) in elevation view?
You can use a Elevation View or you can create a section view near to your wall...
geometric wall opening |
Thu, Feb 19, 2009 at 9:25:31 AM
Geometric Transformation |
Thu, Jul 26, 2007 at 6:14:55 AM
Void Sweep won't cut extrusion |
Fri, Aug 24, 2012 at 3:02:42 PM
Strucutral Columns VS Walls in Call outs |
Mon, Aug 16, 2010 at 8:17:05 AM
Wall sections cut from elevation... now not seen on plan |
Fri, Mar 9, 2012 at 11:05:12 AM
Members: | 2056516 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
