57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Property Line Dimensions
Tue, Jul 13, 2010 at 8:58:26 AM | Property Line Dimensions
Revitized
Revit 2010
Is there a way to actually dimension property lines with length and bearing?  Other than putting the dimension in with dimension lines or non-connected text or changing the prefix, suffix, etc. of a normal dimension.  In other words a dimension over/under/to the side of a property line that would be formatted similar to "160.95'  N 80 23' 45" W".
Thanks for the help.
Tue, Jul 13, 2010 at 10:18:20 AM | Property Line Dimensions
TomDorner
4.5 Stars: 25 Votes
Try tagging with property line tags.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, Jul 13, 2010 at 4:20:28 PM | Property Line Dimensions
Revitized
Tom -
Thank you very much, it works perfeclty.
Take care,
 John
Property line
Tue, Oct 13, 2009 at 5:31:58 PM
ROUNDING VALUE ON PROPERTY LINE BEARING
Fri, Apr 8, 2016 at 1:13:38 PM
How to draw this property line?
Sat, Jan 23, 2016 at 4:48:19 PM
Property line tables on sheet
Tue, Mar 14, 2017 at 1:29:58 PM
Property Boundary lines
Tue, May 30, 2006 at 10:45:32 PM
Page generation time: 0.6894
