51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Family Line Weights
Mon, Jul 12, 2010 at 4:56:08 PM | Family Line Weights
VThokie
1 Stars: 1 Votes
I need certain properties of families to display differently once loaded into a project file.  For example, I need the perimeter lines of a panel to be "heavier" than the reveals and/or other architectural features of the panel.  I have tried changing the panel extrusion properties to something different than the reveals, but because the reveals are in fact void form extrusions penetrating the solid form extrusion of the panel, the properties of the reveals are not editable.  Any help/suggestions would certainly be appreciated. Thanks.
Tue, Jul 13, 2010 at 7:06:07 AM | Family Line Weights
The lineweight of a solid will be the same for any edge of that solid and that would include "reveals".   In families, you can create sub-categories that can be assigned different lineweights but that will not help you in what you describe.
In the model, you can over-ride individual lines in a view (not project-wide) by using the linework tool.
Tue, Jul 13, 2010 at 10:29:00 AM | Family Line Weights
TomDorner
4.5 Stars: 25 Votes
In addition, if you are talking about representation of the object in plan, or elevation views, you can add symbolic lines and turn off the 3D geometry.  As WWHub suggested you can create new sub-categories of symbolic lines as well.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:39 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:33 PM
Line weights
Tue, Jul 24, 2007 at 5:48:21 PM
A Nice set of Revit Line Weights
Wed, Jun 20, 2007 at 8:47:37 PM
exterior elevations and line weights
Fri, Jul 20, 2007 at 12:06:08 PM
Page generation time: 9.5061
