46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Building Pad
Mon, Jul 12, 2010 at 1:41:06 AM | Building Pad
Hashir
How I can take material/volume schedule in 'Building Pad', this is quite important as in the land engineering process we do re-structure the land area, adding lot of material to make the area strong.As a one shot if we can go schedule for building pads it saves lots of our time.My question is this feature is already there, if let me know which version. i use Revit Architecture 2010
- Hashir -
Hashir Abdulla
Mon, Jul 12, 2010 at 7:54:59 AM | Building Pad
You can use the pad tool to cut the topo then create a "slab" on top of that that is your base material and schedule that.
Mon, Jul 12, 2010 at 12:30:01 PM | Building Pad
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
If you are referring to building pads as altering topography, as engineering would normally this is availabe in Revit although it is a little tricky. Follow your help menu very carefully "Graded Region". Review Cut and Fill volumes on a site these can be reported in a cut and fill schedule.
Building Pad Problem
Thu, Dec 20, 2012 at 3:51:09 PM
Building Pad Altering My Topography Surface
Wed, Nov 30, 2011 at 12:02:00 PM
Building Pad and Ecotect
Wed, Feb 2, 2011 at 11:12:07 AM
building pad
Wed, Dec 2, 2009 at 8:34:10 AM
Building pad, what is it exactly?
Mon, Dec 20, 2010 at 11:51:41 AM
14
Page generation time: 0.6518
