44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Making a Clean Split
103 Posts No Rating |
In Revit 2011, I'm trying to split a wall into 3 segments in plan so that the middle segment can be changed to a thinner wall type (think pilasters and infill). The split tool works pretty well in this case since it will break it up into 3 adjacent walls. The problem is that I have no way of snapping to a dummy line that I created to show exactly where it is supposed to split. As soon as I move my cursor to the intersection, it automatically highlights the dummy line instead, thinking that I'm trying to split the line instead of the wall. I find myself making a messy split and just fixing it up later using other tools. In essesnce, how do you split a wall to a predefined point using only 1 command?
Very simple, just split then change the temporary dimension to 0.00, watch the video: http://screencast.com/t/YjE3Y2Q3
Thanks, I think that solves it.
Edit Split Face on Ceiling |
Mon, Jan 25, 2010 at 4:42:26 PM
Wall Split |
Tue, Jul 28, 2009 at 11:52:44 AM
Problem with Curtain wall Mullion clean up at corners |
Mon, Apr 7, 2008 at 9:53:09 AM
using split face tool on curved walls |
Sat, Oct 12, 2019 at 8:21:20 AM
Clean cut below stairs. |
Fri, Nov 30, 2007 at 8:56:15 AM
Members: | 2042257 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
